Translating a graph into number of points
Hi Again,
just to note in here that i can see your function used on the last example but i am not sure if i can use that as i am not familiar with it. i wanted a solution within my territory
Message 11 of 16
(593 Views)
Why don't you attach your code instead....?
Message 12 of 16
(591 Views)
hi
sorry as i cant copy the code, i would once the work is finished.
all i really wanted is to know if there was a way that on a plot running for a certain amount of seconds can i change the number of points of the plot with the plot still rining for te same amount of second.
example, if my plot run for 10 sexonds on the x axis, can the number of plots be 30, or can i can change it to anything i want.
Thank you
Message 13 of 16
(582 Views)
@BobLondn wrote:
...or can i can change it to anything i want.
Yes, you can.
Message 14 of 16
(577 Views)
any suggestions how
Message 15 of 16
(572 Views)
I glanced over the entire thread and it is still not very clear. LabVIEW is a full featured programming language, an everything can be done once you clearly define what you actually want. 😉
If you want to update an xy graph while data is being generated, you can use the xy-graph express VI (uncheck clear on each call). You can also make your own and accumulate the xy data in a shift register and update the graph at every iteration. The terminal must be inside the loop. There is even an shipping example named "xy chart", but it is a bit stale.
Obviously, we have a language problem because most of your questions sound odd and confusing. Maybe you should ask in your native language and somebody can translate (or use google translate, for example)
Message 16 of 16
(564 Views)
