Translation
At 3V analog input signal and waveform capture trigger signal, the signal waveform of the past 10 degree turn to the next trigger signal, we would want to appear on the same graph.
Horizontal axis of the chart this time, between the trigger signal of 100% I would like to view.
Graph is started each time the trigger signal, trigger signal until the end is the following graph.
10 and a new wave appears rotated, a fading wave form 10 times before.
For beginners, the program simple as possible, I hope Itadaketara as possible and tell us more.
Thank you.
(2,708 Views)
This post is problably the outcome of an automatic translator, and looks quite confused. You're better ask in one of the region-specific forums (if available in your language), or ask someone to translate properly.
Furthermore, you should indicate which hardware you're using for data acquisition and which programming language.
Regards
(2,706 Views)
