Transmiss a big array to DRAM
Hello, experts
I want to transmiss a big array (512×512×32) to DRAM. My device is Ni 7962R. I notice that example 'High Throughput Streaming' transmit data by TDMS file. But, how can I convert mat file to TDMS file?
(3,257 Views)
Accepted by topic author OliverZT
Hi. I just do some quick search and found out that to convert mat file to TDMS file in LabVIEW, you need to:
1) Read the mat file in LabVIEW
2) Write the data into TDMS
The first part can be achieved by using DataPlugins and more details about DataPlugin can be found at here.
Meanwhile, the second part can be done easily in LabVIEW. This reference should be a good guide for you.
All the best 😉
Best Regards,
Soo Kin Wah
Technical Support Engineer
NI
(3,181 Views)
For DRAM, see these examples:
\examples\FlexRIO\External Memory\Getting Started - External Memory\Getting Started - External Memory.lvproj
\examples\FlexRIO\External Memory\Random Access\Random Access Pattern - Memory IDL.lvproj
\examples\FlexRIO\External Memory\Memory Integrity Test\Memory Integrity Test.lvproj
\examples\FlexRIO\External Memory\Memory Throughput Test\Memory Throughput Test.lvproj
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,174 Views)
Thank you! DataPlugins helps me a lot! The problem has been solved.
(3,144 Views)
