Transmit And Receive Message CAN same Port
Hi!!!
I have a Issue whit my PXI CAN Card 8464, I try transmit and receive  for the same port, and send this error:
Error 1073094917 occurred at an unidentified location
Possible reason(s):
NI-CAN:  (Hex 0x3FF62105) The size or length that you provided is invalid (too small or large), but the operation continued successfully. Solution: Read the function description and verify that you provide a valid size (or length).
What I do??
(3,748 Views)
Hi Kaliman!
Maybe the following post can help you with your issue:
http://forums.ni.com/ni/board/message?board.id=30&message.id=4015&requireLogin=False
According to it, this is not an error and the communication proceeds. Hope this helps!
(3,725 Views)
Thanks Oswal, when I use this VI, Run well without errors but not read nothig, I mean  I have plug in the device that send message in CAN High Speed 4 message, but I not see nothing and monitoring the Attr value and is cero all time, for this reason I have all time in FALSE the case, thanks for you help
(3,721 Views)
