Transmit data over Ethernet network.
Hello.
I'm a labview newbie and I'm facing serious difficulties with a labview homework I have to do for school.
Basically, I'm currently trying to build a single .vi program to do two separate things:
First it would have to simulate, in real time, the step response of a PID controlled process. For that I used the "control & simulation loop", inside "control design & simulation -> simulation", and it's working fine, I can change the controller parameters and see the results in real-time.
The second objective for this .vi, and that I've not been able to do, is to communicate as a server with another .vi which would be the client. It is suppose to use TCP/IP protocol to communicate between the two .vi's, and the server should be able to send the step response data (the data displayed in the graphs charts).
However it seems that I can't build while loops inside the simulation loop, neither use the response data outside the simulation loop...
I thought I could pull the data outside the simulation loop, and then push it inside a while loop for TCP write and then send it through Ethernet...
Please, I ask for some help with this. Could someone give me some lights or examples on how to do this ?
Thanks in advance.
PS: I attached the .vi file I'm working on to be easy to understand my issue.
(2,974 Views)
Thank you for posting on NI forum.
I think you have to use your second solution (make pid and after transmit data).
To help you with TCP communication, use Labview examples.
Find example... >> Network >> TCP & UDP
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(2,940 Views)
