Transmit data using dynamic ip
i need some guidance .. i need to transmit data from my computer to a server using a dynamic ip. can anyone help me how this thing can be done
Message 1 of 12
(6,830 Views)
You'll need to be more specific. What kind of data? Is the server running some LabVIEW code? Have you looked at the TCP/IP examples that ship with LabVIEW?
Why would a server have a dynamic IP?
Message 2 of 12
(6,802 Views)
Hi  smercurio_fc ,
Im sorry making things so confusing, is it possible to send data (text) from a computer which is using dynamic ip to 2 different servers. I have try using TCP Communicator its work. But i tried with both fix ip's. if i have dynamic ip..how possible i can transmit the message from the server to computer that message been received.
Yup i want this module in labview 8.0, i just need some guidelines..currently i havent started to the module yet.
Message 3 of 12
(6,795 Views)
You should be able to use the computer name rather than its IP address.  Assuming that the computer name can be resolved, it should work just as well as the IP address.  Try doing a ping by computer name in a command prompt window.  Also try doing a ping -a by IP address and see if it returns the computer name.
Message 4 of 12
(6,788 Views)
I agree with raven
There is a function called "String To IP" and "IP To String" and using the combination of these you can get the IP of the PC by providing the Name of the PC.
Regards
Guru (CLA)
Message 5 of 12
(6,781 Views)
Thanks Raven and Guru.
Is it possible either then sending data through ip..i want send data to to a web..example:https//www.abc.com.
how to do this function..can i get an example?
Message 6 of 12
(6,768 Views)
have you tried the web server?
Regards
Guru (CLA)
Message 7 of 12
(6,761 Views)
Hi Guru, not yet tried..i need some guidance on it..Please help
Message 8 of 12
(6,757 Views)
if you just search ni.com you will find lots of resourced regarding this. However as a try go to tools->webservicing tool to launch the same. now select the vi which you want to publish (follow the steps)
Regards
Guru (CLA)
Message 9 of 12
(6,749 Views)
Your question is meaningless. Send what data? Are you trying to create a LabVIEW web browser client? Is there a web service that you want to access on abc.com?
Please provide some substantive comments as to exactly what you are trying to do.
Message 10 of 12
(6,735 Views)
