Transmit data with MAX232 using Labview.
Currently, both transmitter and receiver is programmed using Basicstamp2.
Now I have to change the transmitter programming. Instead of using Basicstamp, I'm using a MAX232 circuit to transmit data to the receiver (which still uses BS2). I have to use Labview to transmit data ti the BS2 receiver. How do I go about doing it.
Message 1 of 9
(5,499 Views)
You need to use the VISA functions.
There are a lot of threads with examples and info. Trere are examples at Labview examples too.
Do a little search and ask if you have further questions
Message 2 of 9
(5,485 Views)
Go under the Help menu and select Find Examples.
Then do a search for "serial".  It will find several examples.  Look at the block diagrams of the examples to give you an idea how it is implemented.
R
Message 3 of 9
(5,477 Views)
Thank you for your suggestions.
I'm now testing out the MAX 232 circuit using the Basic Serial Write and Read.vi.
I tried testing it with loopback (pin 2 and 3 of DB9 shorted) with 5V power supply. When I run the vi, the 'read string' did not match the 'string to write'.
However, without 5V power supply, the 'read string' did match the 'string to write'.
Does it need a 5V power supply for it to work?
If it does, how come it didn't match?
acro
Message 4 of 9
(5,424 Views)
Matches because you have the max232 off, and the short circuit is before max232
Does not work because you should short circuit the pins after the MAX232 (5V logic)
Message 5 of 9
(5,412 Views)
Thank you PNT for your comments.
What do you mean by 'short circuit the pins after the MAX232'?
Message 6 of 9
(5,392 Views)
In which pins of MAX232, do you connect the pin 2 and 3 of DB9 ?
Message 7 of 9
(5,370 Views)
Pin 2 and 3 are connected to Pin 14 and 13 of MAX232 IC respectively.
I tried to short pin 14 and 13 (MAX232) but it's still the same thing as shorting pin 2 and 3 (DB9).
acro.
Message 8 of 9
(5,367 Views)
Short circuit pins 11, 12.
Look at page 7 of max232 datasheet.
Those on left have 5V logic. Those on right, have higher volt logic (rs232)
Message 9 of 9
(5,364 Views)
