Transparency in buttons in LabView
How can i create buttons in LabView with different levels of transparency. I need to see the things below the button. Thanks to all.
Message 1 of 8
(7,529 Views)
HI,
u can use the color brush and choose the transparant color for making the button transparent.
Hope this solves the problem
vicky
Message 2 of 8
(7,529 Views)
Hi Vicky,
i looked the color brush but i could not see the transparent color.
Thanks anyway for your help.
Alex.
Message 3 of 8
(7,529 Views)
There is a "T" in the upper right corner of the color selection dialog. The "T" stands for transparent.
Message 4 of 8
(7,529 Views)
Hi ,
On the top right cornor you will find a button called "T" this is the trasperant color
vicky
Message 5 of 8
(7,529 Views)
Sorry,
I am unable to see the "T" that you say.
Perhaps my Labview version is different of yours.
I send you an image of my brush.
Alex.
Message 6 of 8
(7,529 Views)
I think you have gone to custom colors,just right click with the pointer as brush you will find it on the right top,i have attached a image of the same along with this plz have a look at it,all labview version have this feature,by the way which labview version do u use.hope this helps you.
vicky
Message 7 of 8
(7,529 Views)
i have found the "T"!!!
Thanks for all!!!
Alex.
Message 8 of 8
(7,529 Views)
