Transposing a Vector
I need to work out the following for two arrays (vectors)
XT times Y where XT is the transpose of the vector X. ie suppose for a
simple case
X= [x0,x1] and Y=[y0,y1]
then I need x0y0 +x1y1
This I can do with a loop and a lot of fuss but I wondered if there
was a library function for transposing. I can find one but it is for
2D arrays.
Tom
(3,034 Views)
Tom;
If you are defining your vectors with arrays, then all you have to do is to multiply the arrays. I attached an example.
If you are using something else than arrays, let us know.
Regards;
Enrique
www.vartortech.com
(3,034 Views)
... and then add the results. I attached a new modified example.
Regards;
Enrique
www.vartortech.com
(3,034 Views)
