Trapezoidal Commutation example for NI 9502 not found
I'm  starting to enable the NI 9502 in the cRio 9035 and all manuals says that i have to open the "Trapezoidal Commutation" example installed in the labview\examples\CompactRIO\Module Specific\NI 9502 (as seen in the attachment "Manual") , but in the Module Specific folder there isn't a NI 9502 folder (as you can see in the attachment "Captura"), i did look for a downloadable online but there isn't a single one. Do you  know where can i find that example? or a similar one to work with?
(4,537 Views)
UNBiomed,
I see that is a C Series Motor Drive Module. Have you installed the NI SoftMotion Module already? More information here: Software Required for SoftMotion Hardware.
All the best,
(4,509 Views)
Yes, i already have. There's something i have to do with it in order to find the example required?
(4,488 Views)
Apparently I was looking in the wrong place, sorry about that UNBiobed!
The readme example that is located in the 9502 says:
The NI 9502 examples are now sample projects.
Go to File»Create Project... to get started with the 9502.
Let's see if you see them in said menu.
(4,481 Views)
Hi Oscar, yeah i did read the "readme" example, but it is not in the "create project" menu either. Will it be i need to install something else?
(4,456 Views)
UNBiomed,
I took a closer look at your screenshot, and detected you're looking for the examples in LabVIEW 2019. Please see: Where to Download LabVIEW 2019 SoftMotion Module
I presume you have multiple LabVIEW versions installed, and recommend working in 2018 for now. Please confirm if you do see the examples in a previous version for which you do have the SoftMotion module installed.
(4,451 Views)
