Trapezoidal fit in LabVIEW
I want to select a trapezoidal curve fit for my set of data. The data points are showed in the picture below.
Is there any way to get a trapezoidal best fitting curve in LabVIEW? And is there a way to calculate the area under this trapezoidal best fitting curve?
Thanks in advance,
Dries
(3,315 Views)
You can use "nonlinear curve fit". Follow the help and create a VI model with a few parameters depending on symmetries (amplitude, offset (if any); four key x-positions (or less if the sides are mirror symmetric)). Once you have the parameters, calculating the area is simple geometry, right?
You can find more detailed tips e.g. here.
(3,294 Views)
