Trasnmitting a single sine wave using USRP
how do i transmit and recieve a single sine wave using USRP...i would really appreciate it if someone posted that example
i already understand the blocks of the usrp...but do i need to modulate the sine wave signal or i will just send it..i am really confused
i hope that you may post the example
(3,755 Views)
Hey Eldokch,
See step 4 in the following white paper:
http://www.ni.com/white-paper/13880/en/#toc4
It uses two examples packaged with the NI-USRP driver, "niUSRP EX Tx Continuous Async.vi" and "niUSRP EX Rx Continuous Async.vi".
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(3,721 Views)
