Tree Control Column Auto Resize
I am using touch screen and normal screen and I programatically change depending on the tree control font size. If item name is too long then control is not showing complete name. Are there any way to change the first column size programatically during run time based on item name size?
I am using LV2015 🙂
I. Attila
(4,908 Views)
In most cases I just make the first column extrememly long, like longer than any text I plan on having.  Besides doing that you can inspect what is in each row and what indent it is at, and then set the width to that size using the property node.
here are a couple of links.
https://decibel.ni.com/content/docs/DOC-6521
http://digital.ni.com/public.nsf/allkb/69BD25A34A2D3199862572B1006B7B31
(4,878 Views)
Hi Hooovahh,
Thanks for your response. Try it you sent.
(4,839 Views)
