Tree Control shortcut menu activation event with touch screen
Hi
The shortcut menu activation event in a tree control doesn't work with a touch screen.
It only triggers when we right click(right click in touch screen means click and hold) in the + or - signs, not in any other place.
Any ideas to solve this? Or any similar experiences?
Also the on mouse down event can't be used because 2 events are triggered for the right mouse click (the first output=1 (left mouse click) and  a second output=2 (right mouse click)) , but for this I can use the mouse up event.
(3,381 Views)
Hi IDILIO,
Thank you for posting on National Instruments Forum,
Looking at the context help (Ctrl+H) on the event "Shortcut Menu Activation?", you will see that it is "Generated when the user right-clicks a control to display the shortcut menu".
So the behavior you encounter  is the normal one.
Have a nice day,
Flo
(3,335 Views)
Sorry Florent A. but I can't understand your answer. The user is right-clicking in the control and the shortcut menu doesn’t appear! Its happening exactly the opposite of what is described in the context help.Clicking in the + or - signs works, but clicking in any other place (inside the control, OBVIOUSLY!) doesn't work. It works ok with the mouse. Idílio
(3,332 Views)
