Tree Control with checkmarks for selection
In my project I neede to use a tree control with check marks associated with each item which should allow users to select or deselect a particular item. Once all the item selection is done, I need to read the parent items selected and also the selected child item associated with each parent item. Please let me know how this can be implemented in LabVIEW.
Thanks in Advance.
Sri Vidya
(4,631 Views)
Did you try looking at the shipping examples? Help -> Find Examples. Search for "tree". Open the example "Setting Custom Item Symbols". Or "Traverse Tree and Set Custom Symbols".
(4,613 Views)
You can then use the checkmark symbols from the LabVIEW glyph library or dowload one from google image.
Ben64
(4,608 Views)
Maybe you could use this.  Call this VI from a Value Change event of the tree.
(4,602 Views)
Hi pcardinale,
The attached VI is looking for Get_All_Tree_Items.vi which is not found. Also it is looking for the customised list ring control Symbol(check). Please let me know if you can send these as well to understand the flow and reuse in my application.
Thanks a lot for the inputs.
Thanks and Regards,
Sri Vidya
(4,585 Views)
Sorry about that.  Here's the whole set.
(4,568 Views)
