Tree control double click default behavior
Hi all,
Tree control have default behavior that expand/ collapse item when double click event occurs on parent item.
How do I to avoid this behavior to use custom double click event without open close nodes?
regards
(4,132 Views)
I was not able to disable the default event however I realized a VI that could be useful for you.
I've used a method to force all the tree items to be collapsed.
Take a look at the attached image.
Alex
(4,115 Views)
Accepted by topic author euTeam
Thanks but I found solution filtering open item/close item events like in picture.
Regards
(4,057 Views)
