Tree control selection
OK, so this should be somewhat straightforward, but I am unable to find how to do this.  I want to fire an event when I select an element in a tree control and then determine which element was selected.  Right now I can use the double-click function in the invoke node associated with the tree control, but there seems to be no way to determine what row currently has focus.  Thoughts?
Message 1 of 8
(6,367 Views)
Why not just use an event structure to capture the current value?  Maybe I am not understanding your question.
aputman
Message 2 of 8
(6,331 Views)
Nothing is changing - I simply want what the user has selected (not entered or changed).
Message 3 of 8
(6,324 Views)
Accepted by topic author cirrusio
Ok...that's the value change event, exactly what I show in the pic.  There is a double click event, item open event, etc.  See attached for a few examples.  If this doesn't help you any, please be more specific with your question.
aputman
Message 4 of 8
(6,322 Views)
So, something to note here for posterity.  The value change event does not work this way with the silver tree control.
Message 5 of 8
(6,267 Views)
I'm not sure what makes you think so.  I just tested it on LV2016 and value change event does fire for a silver tree control.
Message 6 of 8
(6,258 Views)
It works exactly the same way in Labview 2012 and 2017.  Show me what you mean.  Share some code showing otherwise.
Right click the tree -> Selection Mode.  Do you have Allow Selection of Parent Items unchecked?
aputman
Message 7 of 8
(6,257 Views)
You are correct - it is working on 2016.  It is not working on 2013 from what I recall (I had to change to modern to get it to fire on selection).
Message 8 of 8
(6,253 Views)
