Tree control tip strip for each item
In tree control is possible set a Tip strip for each item (node) of tree?
In tree control  tipStrip property seems relative to all tree.
Thanks all.
(2,973 Views)
The only thing I can think of is to use an event structure
  • use a mouse move event
  • Get Cords
  • Calculate what item the mouse is over
  • Use a Tips property node to write the correct string.
The hard part will be calculating what item the mouse is over, The Displayed Items property node should help.
I am actively working on a program that is centered around a tree control and might like to do the same.
If you need further help reply back
Omar
(2,968 Views)
