Tree view set symbol error 1135
I try to build tree by program (reading by file tree structure) using invoke node 'Edit Tree Items.Add.Item' and this work fine.
Now if I try to set symbol index after item added using property node, rise an error 1135 : 'The tree control's active item is not valid for this property.'
What I wrong?
Thanks all.
(4,021 Views)
can you attach the code?
Regards
Guru (CLA)
(4,018 Views)
Code is quite complex, I prefer not send it.
I try to reproduce a little subset of code, but this work fine!
Thanks.
(4,013 Views)
Accepted by topic author euTeam
Ok I understand my error:
in property node I have set symbol index BEFORE ActiveItemTag!
Order is important!
Regards
(4,002 Views)
