TreeView control in labview 6.1
I am using the activeX TreeView control.
Is there a property that will allow when setting the checkbox of an item set the children of that item in the tree view when expanded. Or have I to do it programmatically.
Regards
Ray Farmer
Regards
Ray Farmer
(3,058 Views)
TreeView subclass "Item" have properties "Checked" and "Expanded".
if Item.Checked then Item.Expanded
(3,058 Views)
What I was hoping for was when you check a parent then its children when expanded are already checked. But I guess I'll have to check the children my self before expanding the branch.
Regards
Ray farmer
Regards
Ray Farmer
(3,058 Views)
