Trendnet Camera
I know this question has been posed several times before, however I was wondering if anyone had managed
to gain control of Trendnets cameras through LabVIEW.
I am currently trying to get the feed in from the camera through labview....and perhaps access pan tilt
and zoom commands through the active x containers...
The current camera I am using is a Trendnet TV-IP410...
Worst case...how to open the just the stream through LabVIEW becuase an IE box
allows alot of options for the camera thus I would not want the user to see these.
(3,111 Views)
Hi majorpro13,
1)  Can you control your IP camera using w webbrowser,if that is the case,you can use the webbrowser in Labview?
2)Have you got any software along with the camera?Then find some ways to communicate to that software through activex?
3)Are you getting any data if you are using TCP/ip vis?
Thanks and regards,
srikrishnaNF
Srikrishna
(3,101 Views)
majorpro,
Please send me a private message regarding this issue by clicking on my username then selecting "Send this user a private message" in the Contact section.
Zach C.
Field Engineer
Greater Los Angeles
(3,063 Views)
