Trial and Error math?
I was drilling down into an express VI "Collector" and was writing off the use of FP controls that are not on the icon connector being used to save state from call to as being due to the Express VIs being older than feedback nodes and then I stumbled across this ...
after drilling down a couple of layers. Again ignoring the array wired to the While loop but the functionality of the While Loop had me scratching my head and thinking Whiskey Tango Foxtot ?
Can someone explain what that while loop is doing?
Ben
(3,846 Views)
Iterate untill 1 based loop counter crosses specified value
Looks like a very funny way to do subtraction...
Result of the whole case structure in true case is just Size, as it should be: if array long enough, take last Size elements that you need to hold.
(3,806 Views)
It's adding 1 to a counter again and again until the counter equals the difference of the two values being subtracted from one another.  Don't you like doing things the Rube way?
aputman
(3,805 Views)
Do you still like express vis?
(3,785 Views)
