Triangular LED with labview student edition
Hallo, im new to LabVIEW, i wud like to have a Triangular LED for my project. I see there exists solution for normal version.
http://forums.ni.com/t5/LabVIEW/How-can-I-make-a-triangular-LED/m-p/613889
Unfortunately i use LabVIEW student edition, so above solution is not compatible. Does any body having other solutions?
thanks, Madarapu
(2,771 Views)
Accepted by topic author madarapu
Why do you say it's not compatible? According to the specs, the Student Edition has all the capabilities of the "normal" version, so the Control Editor (which is what is used to create the LED in the example you linked to) is available. Have you tried to perform the steps as indicated? If so, was there a specific one that didn't work?
(2,762 Views)
Thank you smercurio .... i have missed the 3rd step clicking on the spanner.. i thought spanner means something else.
any way, this is how starters do 😛
Thank you for your clarifications on Student edition that this edition also like normal version. Wish you a nice day.
(2,723 Views)
