Trick on separating lines has random string but; at the end from textile
I have a text file like below (I copy 2 loop from the whole code) as you can see all these string and numbers are random. I want a code that can separate the blue part of the code for me in array.everything under {   }; I used match pattern but its only get the first loop and not for the whole code.
BLOCK
                ABCD_BSU2_TSET <BSU_ ORCAM _CED: 0x000> 32 KLC="hclk"
                DER_KHU_1_0   7:6 NUM DEF=0x0 RW;
                FRTY_1_RTGC   5 NUM DEF=0x0 RW;
                FG_DERF_1_0   4:3 NUM DEF=0x0 RW;
                K_DF_SWRD_DHDDI   2 NUM DEF=0x0 RW;
                L_DFTF_SHDD_DH   1 NUM DEF=0x0 RW;
                SHDDU   0 NUM DEF=0x1 RW;
                ABCD_BSU_LLP <BSU_ORCAM_CED: 0x004> 32 KLC="hclk"
                HDGDFD   7 NUM DEF=0x1 RW;
                EDT_n   6 NUM DEF=0x1 RW;
                HGD_l_SDR_5_0   5:0 NUM DEF=0x19 RW;
the rest of the code
Message 1 of 38
(3,686 Views)
Put your Match Pattern inside of a While loop.  Make it stop when the expression can't be matched (index will be -1).  You will also need to keep track of the Index After Match in a shift register so that you don't repeatedly get the same set.
Message 2 of 38
(3,643 Views)
I have already tried that. but the loop does not take my 2D array input string. i tried to add 4loop but did not help. ....for regular expresstion are you using ; or {}; ? which one?
Message 3 of 38
(3,620 Views)
I don't know where you came up with a 2D array.  Here's what I came up with.
Message 4 of 38
(3,616 Views)
Don't read the file using "read from spreadsheet file". Use the plain "read from text file", giving you a plain string..
Message 5 of 38
(3,605 Views)
please ell me what I am doing wrong! I only get the first loop and i dont know how to make it continue.
Message 6 of 38
(3,589 Views)
sorry wrong file look at this one
Message 7 of 38
(3,584 Views)
Why don't you use the code suggested above?
Message 8 of 38
(3,578 Views)
  1. Initialize your numeric shift register to 0
  2. Don't wire the initial string into the string shift register.  You want to pass it in using a tunnel.  Actually, you don't even want the shift register anyways.
  3. Use the Index to Start for your first Match Substring.  Pass the Index After Match of this function to the input of the next.
  4. You will need to autoindex the matched portion out of your loop.  This will result in a 1D Array of Strings.  Adjust your later logic accordingly.
Message 9 of 38
(3,569 Views)
I did but I get all the code to my output .. can not see what he is using after loop, insted I used "spreadsheet string to array" ..
Message 10 of 38
(3,557 Views)
