Trigger Output of Thorlabs BBD302 Controller using Kinesis in Labview
I am currently working with the Thorlabs BBD302 benchtop brushless controller. I have already implemented a 2D raster scan in Labview and I want to generate a trigger output signal (the signal is high when there is a movement in x-direction) to control an external camera. But I didn't find how to set the trigger output (maybe with SetTriggerSwitches) and how to get the output signal of it so that I can show the signal in a graph. Looking forward to your reply!
(1,727 Views)
Hi, I don't have a solution to your problem, but I have been struggling to get the BBD302 to work well with LabVIEW. Could you possible share your code? Thanks
(930 Views)
