08-15-2007 01:14 PM
08-16-2007 03:33 PM - edited 08-16-2007 03:33 PM
Hi M^2,
If all your trying to do is a software timed trigger as shown in the vi that
you provided, theres a few things that I would change. First off, I would
create the digital output channel and start it prior to the loop. Second,
I would initialize the value of the digital output to high (I was using an
inverse logic LED output) prior to the loop. Then after the trigger is
found, write the digital output to the opposite (low). In addition, I
changed the DAQmx read to 1 channel with N samples (1D DBL). This seemed
more appropriate if you’re just using one analog input channel.
I've gone ahead and uploaded the code I modified. This is setup to my
parameters. Basically, I triggered when my thermocouple voltage rising
edge went over 0.29V. You will need to change these settings back to what
you need for your application. Also, I wanted to note that once the
digital output is changed low when the trigger is found it will remain low
until changed high again.
I hope this helps,
Paul C.
Message Edited by Paul C. on 08-16-2007 03:34 PM
08-16-2007 04:19 PM
08-16-2007 06:31 PM - edited 08-16-2007 06:31 PM
Message Edited by Paul C. on 08-16-2007 06:39 PM
