Trigger Timeout 10800
I have a PCI-6052E DAQ-Card and LavView 6.1. In my LabView program there are two different types of data aquisition: 1.) the card is triggered by an internal clock and 2.) the card is triggered by an external clock. However, before my system crashed, both modes worked fine. At the moment just the 'internal clock mode' is running. I already looked at the external trigger signal and it seems to be ok.
Thanks for all suggestions!
(2,780 Views)
The Error code tell us that the problem is the time limit. The Card didn't get any External Trigger at the time you spec.
So mybe your problem is at the trigger config. try to change parameters at this VI, or tell us more about youe Acq. VI & the kind of sampling you are trying to reitrive (pre-trigger Acq or Post-trigger Acq).
Hope it Helps...
(2,780 Views)
