Trigger function not working?
Hi there,
I'm not quite sure why, but my whenever I execute my trigger function, my waveform disappears. (I'm still new to LabVIEW, so I'm sure it's an easy fix; I just haven't found the right solution, yet)
I have attached my troubleshooting VI. This VI is just a part of the bigger program. The whole program actually has another trigger function that works fine.
Any guidance would be appreciated.
Thanks so much!
(3,331 Views)
Accepted by topic author MauiLani808
You didn't wire the input signal 🙂
However, I'm not certain if you do wire the input, that will completely solve your problem. I'm guessing you want it to stop the loop whilst it is triggered?
(3,324 Views)
OH. MY. GOSH. Well now, I'm embarrassed. Thank you so much for being my second set of eyes!
(3,299 Views)
