Trigger out from USB6002 to trigger a camera - labview code
Dear all,
I have an application which needs to trigger an external camera. I am trying to use USB6002.  It needs to send a trigger output to the camera every time a loop in the application is executed.
I was expecting it to be straightforward using DAQ Assistant. I am sure others have implemented it - any chance someone could share the code or assist me in this.
I require this for a research project in a university - any help would be appreciated.
Kind regards
(1,976 Views)
Accepted by topic author dr227
Modified from shipping example <LabVIEW>\examples\DAQmx\Digital - SW-Timed Output.vi
https://tmesystems.net/
(1,969 Views)
May I ask for another favour. How can I read a trigger within a tabview application to capture a frame?  It should wait for the trigger before capturing.
Many thanks
(1,890 Views)
Many thanks
See How Can I Synchronize/Trigger My Camera to External Signal?
(1,886 Views)
