Trigger using DAQ 6015
Hello everyone,
I'm relativley new to LabView and am not entirely sure if I'm using it correctly.
I want to use the NI-DAQ 6015's digital output as a triggering source for another device. However what I thought would be the right way only returns error 200452 which I don't qute understand.
I attached pictures of the labview routine (parts in the ovals were added by me) and the error message.
I would appreciate any help by you.
Kind Regards
David
(4,433 Views)
The basic issue is that all hardware devices don't support all functionality.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,417 Views)
Hey Mike,
Thanks for your response! I know that not all hardware can support all functionality, but isn't the entire trigger sequence I used software based? All the parts outside the oval work and am I not using the same sequence there as well?
David
(4,386 Views)
What I mean is, there must be a way to synchronize the digital output and the analog output on the same device? Or is that assumption wrong?
(4,368 Views)
Hi Dave,
as said in the German LabVIEWForum: Please mark your messages as Crosslink (atleast for the German reading audience)!
There already was some discussion about your problems and you should make the people in this forum aware of the full story…
(4,363 Views)
Hi David,
no the trigger sequence is HW-based, since the trigger normally a piece of hardware set to start your task on a certain condition. It is configured from SW, but done from HW.
"Triggering" by SW would involve a fast polling of the signal, a SW analysis and a SW based start of the task. That would be non-deterministic and would take many ms, instead of a few ns/us.
Sorry that your HW doesnt support that.
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,362 Views)
