06-15-2010 04:00 PM
I'm new to Labview and I am having difficulty trying to make this work correctly.
What I'm doing is monitoring the output of a transducer and when it reaches a certain critical value I want it to write the data to a file.
I have this part working okay, but I'm currently using a greater than / equal vi to check the value against the instrument stream, so when the value drops below the critical value it stops recording. I want it to continue to record for a set number of mins after the critical value is reached.
How would I do this?
Solved! Go to Solution.
06-15-2010 04:17 PM
06-16-2010 01:57 PM
Thanks!
I figured it out using the Elapsed Time VI like you suggested.
07-08-2019 06:02 PM
I have exactly the same question,
I attach my data acquisition code to this message.
I want the code trigger "writing" whenever the amplitude of signal >= 0.5 V.
Could you please help me with this matter?
Peter
07-09-2019
05:57 PM
- last edited on
10-09-2024
09:39 AM
by
Content Cleaner
Were you able to try implementing the Elapsed Time Express VI as previously suggested?
Here is some additional documentation on the Elapsed Time Express VI for your reference:
