Trigger
I have two PCI-6110E cards in one station. Each card has four channels. My
problem is that I would like to get eight signals with LabView, and each
card should have the same trigger-signal (first card, channel 1). How can I
trigger the second card with the signal of the first card. There is a port
on the card (this port you cannot see outside the station), I think with 10
pins. Have I connect the two cards with this port?
Ralf
(3,023 Views)
The internal connector that you are referring to is called the RTSI connector (Real-time System Integration). You will need to make connections through this connector to trigger one PCI card from another.
To see the pinout of the RTSI connector, take a look at the following link.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ad2d553f55a07bbf8625650d005f1f00?OpenDocument
Here's another document which describes how to synch two PCI boards using RTSI.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/6ec96c76111d2e6a86256628008071a0?OpenDocument
Mark
(3,023 Views)
What shall i do with a link with prohibited access ?
(Pinout of the RTSI connector)
(3,023 Views)
