Triggered data acquisition on 3 channels with pretriggering
I'm trying to perform a data acquisition using a daqpad 6052. I have 3 chanels 0,1 and 2. I'd like to trig on chanel 0. And have a pretrig of 5000 pts.
LV tells me that "NI-DAQ LV: The specified trigger signal cannot be assigned to the trigger resource."
-10621
Thanks for your help
(2,949 Views)
Try an example that ships with LabVIEW. Note that not all sources can be set as a trigger. Also, make sure that channel 0 is the first channel in the channels list.
RamziH.
(2,949 Views)
I'm using the exemple "Acquire N Scans Analog Hardware Trig.vi" from NI to test this. I specified chanel 0 and 1 and trigger on chanel 0. If the pretrig param is lefet to 0 is works fine but if a set it to 50 it gives me a configuration problem. I have included the vi with the parameters saved in the interface. Check this out.
Thanks. You can contact me directly if needed at landry.champlain@ireq.ca
(2,949 Views)
