Triggered sequencing of continuous signal
I am currently trying to build a VI which is able to cut a 1kHz periodic signal on one channel of my BNC box with an external trigger on another channel of my BNC box. This way I want to obtain packages of single periods  which are sequenced during the measurement, not afterwards.
I tried different VIs, but none of them was working properly. The best I got right now, is the one in the attached picture, using "basic level trigger detection.vi" and a get waveform subset vi. The problem is that the chopped sequences are not of the same length, even though I give the number of samples after the trigger signal as an input to the waveform subset vi.
I hope my problem and the wanted outcome is clear. I would be very thankful for every idea.
MaLe
(3,339 Views)
Hi MaLe,
finally your aim is to cut a specific amount of samples after a trigger signal is occurred. I would recommend using DAQmx functions, so you can configure the trigger signal and set the acquired data to a specific amount.
I attached a screenshot. Be aware you are able to drag&drop this screenshot in the blockdiagram of LV 2012. So you have already the code.
Kind regards,
RupiDo
(3,304 Views)
Hey.
Thanks for your answer. The problem is, that data is being lost in between the finite acquisitions of n samples, which is not fitting to my requirements... I need a continuous acquisition.
But thanks anyways.
(3,293 Views)
now we have modified the example, so the card is continuously acquiring data and the rist 200 samples after the trigger signal are written into a queue.
Now you are also able with array and waveform functions retrieve a specific amount of samples.
Kind regards,
RupiDo
(3,286 Views)
Hey.
Thank you again...
The problem is still there.
I dont have a trigger to use the "DAQmx start trigger" vi.
I just spent some time trying to make your vi work for my case and i think it is impossible, because i want to use an analog square signal on channel1 of my PXIe-6124 to trigger the analog signal on channel0.
I think my card cannot do this. I probably need a software solution for my problem. I built one that reads the trigger channel, finds the trigger time and uses the trigger time to sequence the actual signal. It works, but the signal is getting a bit shorter with every chopped sequence... that means it ALMOST works.
any idea how i could solve this problem?
(3,274 Views)
Hi Lehrm,
the analog trigger signal shouldn't be the issue. The PXIe-6124 supports an analog trigger
. Check following link:
Which S-Series (61xx) Devices Support Analog Triggering?
http://digital.ni.com/public.nsf/allkb/074CF0F18BB49F9D862570260078DCE0?OpenDocument
Please try to set the trigger to analog and select for source: "DevX/ai1", so the trigger signal will be retrieved from channel1.
Kind regards,
Rupert
(3,265 Views)
I have the same requirement, but my device is different. I acquire signal from NI 9239 module which does not support hardware triggering. I can only use software triggering.
Could you please give me any suggestion!
(3,105 Views)
