Triggering a button when a voltage pulse is detected?
I have a daq with a voltage pulse input of 5V (+/-0.2ish) that I am using as an event marker. It is a ~1 sec pulse  as shown in the attached photo. image.pngHow can I set a trigger in my while loop to place a data marker every time this is detected but also have it so that a user can input a marker whenever they like via a button?I have tried to use the peak detection function with varying thresholds but none of them seem to work (due to the noise maybe?) and I get multiple instances of True resulting in multiple markers placed each time the voltage is detected. The code i am using for this marker placement is pasted below as well. image.png
(2,296 Views)
Check this example. It is not exactly what you want, but it shows how to add markers programmatically. Use it as a reference.
(2,251 Views)
