Triggering a snapshot of data while simultaneously logging all data (from same DAQ)
I am trying to log all data from my DAQ at a slow frequency, but I want it to capture at a higher frequency when a certain trigger occurs. As of right now, I have two separate while loops going at once (one with the slow logging and the other with the trigger logging). Is there a better way to do this? Is it possible to reduce this down to one while loop and still capture all the data in real-time? I found something in the DAQ assistant called "Logging" but I am not sure if this will help in this case. Thanks!
*Note that the "Enable Snapshot" and "Take Snapshot" buttons must be toggled from ON to OFF consecutively, as of now. I.e. Enable ON, Enable OFF, Take ON, Take OFF
(3,167 Views)
Anyone?
(3,119 Views)
Hi ntsirak1,
I have a couple suggestions for you. First is to let you know that you can acquire at a certain frequency and then decimate the acquired data to log certain samples, giving the impression that you are logging data at a slower rate. Here are some LabVIEW functions you could use to decimate the acquired data:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/decimate-1d-array.html
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/2dsp-llb/decimate-continuo...
Additionally, you can use the DAQmx Configure Logging VI to save your acquired data to a TDMS file, but once the acquisition has started you cannot stop the data logging process. Here’s some information on the DAQmx Configure Logging VI:
https://www.ni.com/docs/en-US/bundle/ni-daqmx-labview-api-ref/page/vi-lib/daqmx/configure/task-llb/d...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGedSAE&l=en-US
Lastly, here’s an example that I’d like you to take a look at. This example implements a continuous acquisition with producer/consumer architecture that allows you to enable/disable data logging with a Boolean button. I think this example might come in handy for your application.
https://forums.ni.com/t5/Archive-TKB/Using-Producer-Consumer-Architecture-for-DAQmx-Read-and-Write-t...
I hope this information is useful to you. Let me know if you have any more questions or concerns.
Regards
(3,098 Views)
Thank you for your response! This might be exactly what I'm looking for
(3,082 Views)
