Triggering an event case only once after the Timeout event
Hi all,
I'm trying to find a way to trigger a specific code only once after the Time out event in the event structure. I have many events that are handled by that event structure, otherwise it would have been a lot easier. I'm aware of the producer and consumer structure but it's tedious and I think there is a better way in such situation? any help is appreciated, thanks.
(3,448 Views)
Accepted by topic author AHmedalnahdi
Your question is a bit vague, without any code i cant give a lot of suggestions.If by once you mean only the first time the timeout case executes you could use first call and execute the section of code only on the first time the timeout case happens.
-Matt
(3,409 Views)
Exactly!!!. thanks for the info and sorry for my bad explanation .. good luck .
(3,404 Views)
