Triggering analogue measurement from counter signal
I am building a small rig to test the noise levels of infra red detectors and am driving the source with a counter from my USB 6211, I need to be able to measure the peak and trough value of the measured signal on each cycle. I  need to be able to trigger a measurement at the same point of each cycle and thought I could use a second counter synced to the first to trigger when to sample/measure the analogue measured signal. Firstly how do I synchronize the signals and then use the second to trigger continuous measurements?
I have attached a picture of the wave I need to sample/measure.
Message 1 of 1
(2,308 Views)
