Triggering frequency measurement with 9402 and cDAQ
Hi all,
I'm trying to take a speed measurement off of a shaft using a hall effect sensor and a 9402 module in a 4 module cDAQ 9174 chassis. I've used the low frequency measurement example using DAQmx but if the shaft isn't spinning I get a timeout error.
Two questions, is there a way to use the Express VI's to accomplish this and how do I create a trigger to start the measurement?
-Ian
(3,165 Views)
Why not clear the timeout and report 0 RPM.  The timeout is 0 rmp but you dont want to wait forever and block program flow.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,157 Views)
Yes, that is exactly what I'd like to do but how can it be achieved without causing the program to hang?
-Ian
(3,141 Views)
In the read, specify a timeout.  the read will return and not block.
Paul Falkenstein
(3,132 Views)
