Triggering problems with picoscope 3205 (LabView)
Hi.
I have a problem trying to trigger my signal in order to see it clearly. My target is to measure a periodic signal of hundreds of microseconds. I have used the program ps3000_runStream and changed all constants to control. But the point is that some of them doesn't work properly and I am a begginner with LabView. I have tried using Picoscope 6 (Picotech's software) and all works, but I need to have the same in LabView because I am going to add some components to measure at the same time. My program is attached to this message.
Message 1 of 1
(3,223 Views)
