08-29-2007 03:32 PM
Yes, 300 msec is relatively long. You can experiment with the trigger delay setting. this works with an external trigger. You might want to verify that the dealy aslo works with a software trigger.
I asked you why you can't connect the same signal from the scope to the DMM's trigger - remember? You said you counldn't because you had 15 different loads.
08-29-2007 03:45 PM - edited 08-29-2007 03:45 PM
Message Edited by Roons1159 on 08-29-2007 03:46 PM
08-29-2007 03:51 PM
