05-03-2006 11:19 AM
05-03-2006 11:40 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-03-2006 12:02 PM
Before you go any further with traditional DAQ VIs I suggest you take a peek at some of DAQmx Synchronization examples. DAQmx makes this type of thing MUCH simpler once you become familiar with its paradigms. If you don't have a good reason for sticking with the old DAQ, switch over now. You'll find that your app will be so easy to code it's almost embarassing.
05-03-2006 12:08 PM
Ok, ok i know MX is better but i dont know how to use it at all.
But since im on a tight time table can sombody help me fuble thru this in Traditional?
Im getting my wisdom teeth out soon and will have plenty of time to play with MX, also i do have hardware that is NOT mx supported.
Anybody look at my VI's? Could you? Thanks.
05-03-2006 12:49 PM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-03-2006 01:11 PM
