Trim Whitespace in LV 7 and Open G conflicts
Hello
I've installed the OpenG-Toolkit on my Labview 7 installation.
Now when i want to insert the "Trim Whitespace.vi" from NI, the one from
the OpenG toolkit get's inserted!
How can I change this behaviour? I want to compare the two, since the
Trim Whitespace from OpenG uses Match-Pattern which is really slow,
especially if there arn't any whitespaces to trim! 😞
Bye
Marco
(2,794 Views)
Marco,
The next release of the OpenG toolkit will fix this problem by adding a suffix to all the OpenG VIs so we will not get name conflicts. For now, you'll need to rename the OpenG 'Trim Whitespace.vi' yourself.
You'll find the VI under, "LabVIEW 7.0\OpenG.lib\palette\functions\string\string\string.llb". Try renaming it to "Trim Whitespace__ogtk.vi". Note, this is not actually in a library, but in a directory named 'string.llb'.
After you rename it, you'll of course have to relink any applications that used one or the other to the correct one. You will now be able to open both of them at the same time to compare them.
The LabVIEW version is located at "\LabVIEW 7.0\vi.lib\Utility\error.llb\Trim Whitespace.vi"
The LabVIEW version also uses 'M
atch Pattern', the main difference is they use a slightly different regular expression for searching.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,794 Views)
