Triple Green Down Arrows in Typedef ctl
I was modifying a typedef and I sometimes see the triple green down arrow icon on display right below the menu. Please see attachment. Does anyone know what does this icon is called so I can do a search of what it is. When does it appear?  Any ideas?  Thanks!
(2,756 Views)
Accepted by topic author SmplLbV123
Hi SmplLVV123.
This is the "Synchronize with Other Application Instances" button referred to here:
LabVIEW Help: Working with Application Instances
https://www.ni.com/docs/en-US/bundle/labview/page/working-with-application-instances.html
This is seen when making modifications to code (or network shared variables, etc.) that exist in multiple applicaiton instances (typically different targets in a project) - this updates the copy in memory for each instance.  Since you were modifying a typedef, it sounds like it needed to be synchronized across multiple targets.
Tom L.
(2,753 Views)
