Trivial But Annoying ...
Everytime I create a property node the label of the property node is in bold (even though the object that I was creating a property node from did not have a bold label). I'm guessing there is a setting somewhere, but I can't find it. And I know, I know, it's not a big issue but it is annoying and I can't just leave them bold. That interfers with the look of my beautiful code. Thanks!
-- Jason
(3,010 Views)
Check your LabVIEW INI file for weird font settings...if you see any entries like FPFont or BDFont (or something like that), delete them and restart LabVIEW.  Other than that, I'm not sure what the problem might be.
-D
(3,002 Views)
Hmmm, doesn't look like anything suspicious is in the .ini file. I'll guess I'll do a re-install once I finish with this current project. Thanks for the suggestion!
-- Jason
(2,959 Views)
Before you go that far...
Just rename "LabVIEW.ini" to something bogus and restart LV.
Ben
(2,956 Views)
I also had this annoying problem, but I could solve it with the help of this forum.
I'm refreshing this old thread just to point to the right direction anyone that jumps here searching a solution.
Certainly, deleting the ini file make the problem disappear, but a better suggestion was given here (see the reply from Greg McKaskle).
Thank you again to all the valuable forum contributors!
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,882 Views)
Thanks pincpanter! Now I just wonder why my search attempts did not find that thread. 😉
-- Jase
(2,855 Views)
