Trouble Running Built Applications in OS X
I am running Labview 8.2 on OS X and I am having trouble with the LabVIEW run-time engine. The application I built runs fine on the machine it was built on, but when I copy the application over to a different computer it does not work. I'm a little unclear on how the run-time engine is supposed to work. When I double click on the .app file, the LabVIEW 8.2 spash screen appears followed by a "Select a File to Open" dialog box. I'm not sure what file I'm supposed to select, but I assumed it was the .app file. However when I selected this file it gave an error message saying that it was not a valid LabVIEW file.
I upgraded to 8.5 and got the run-time engine for 8.5 and the same thing happens.
Am I missing something? Is there any documentation for the run-time engine? Most of the stuff I've found seems to only apply to Windows.
Thank you,
Mike
(3,376 Views)
Are you sure that the executable you build is build correctly?
Seems like it can't find the main VI.
Try and select a dummy VI on the run-time only machine and see if it starts.
André
Message Edited by andre.buurman@carya on 09-12-2007 08:53 AM
André (CLA, CLED)
(3,365 Views)
I'm not sure that I am building the app correctly. I made an extremely simple, one VI project and compiled that, but it also said that was an invalid LabVIEW file.
I'm a little unsure about your reply André. The compiled program is a .app, so there aren't any VIs. There are four files that are created by the build: program.app, program.aliases, a preferences file and a preferences.bak file. When I double click the program.app file, it shows the LabVIEW spashscreen, then asks me to select a file. If I select the program.app in this file select dialog, it says that it is an invalid LabVIEW file.
Thanks for your reply,
Mike
(3,332 Views)
I ment instead of selecting the .app select the .vi the app was built from.
It is possible to start VI's in a run-time only environment using a build executable.
André
André (CLA, CLED)
(3,306 Views)
I'm still not having any luck. When I try to run the built executable on the machine that LabVIEW is installed on it works fine, but it does not work on the run-time only machine. This is with the extremely simple, single VI program.
What kind of settings in the build specifications could mess the executable up enough to make the run-time engine think that it's not a valid LabVIEW file?
(3,271 Views)
Have you tried re-installing the run-time engine?
Or build an installer on the dev machine and use the installer to install the exe with a new runtime (don't forget to uninstall the current runtime first).
André
André (CLA, CLED)
(3,258 Views)
I haven't tried reinstalling the installer, but it was a fresh install on a computer fresh out of the box. I'll give that a shot though.
As for making an installer, I think you can only do that in Windows.
Mike
(3,245 Views)
