Trouble generating 50MHz clock digital output with myRIO-1900, sbRIO-9602, and PXI-7811R
Hi all,
I'm trying to drive a DS92LV16 16-bit Bus LVDS Serializer/Deserializer chip using any NI FPGA I have my hands on. The problem is that this chip needs as a minimum a 50 MHz clock. My FPGA boards all have 40 MHz built-in clock, and when I use a derived 100 MHz clock to generate a 50 MHz digital output, the signal comes out weak. What is mean is the oscilloscope is showing a peak-peak amplitude of less than 1 Volt when running at 50 MHz. When I drive a 4 MHz clock through a digital I/O pin I get nice peak-peak signals around the 3.3 V needed to drive CMOS logic.
Can I use the myRIO-1900, sbRIO-9602, or PXI-7811R to do this? Can newer hardware help? If so what models would work? Or can I use a buffer chip to precondition the signal for driving hardware?
Thanks!
(2,966 Views)
Here is what the signal looks like on my oscilloscope at 8 MHz. See attached.
(2,950 Views)
And here it is again at 50MHz. Major voltage drop. Not high enough to clock the CMOS chip I'm driving at 3.3V.
(2,949 Views)
You've mentioned three different FPGA's. Which one is currently showing this behaviour? I wouldn't be surprised if it was the myRIO but the 7811R should be able to achieve up to at least 40Mhz, have you tried the 7811R at 40Mhz?
(2,935 Views)
I mention three systems because these are the systems i’ve tried to generate a 50 MHz clock. They all exhibit the same behavior as shown in the pictures I uploaded.
(2,920 Views)
