Trouble interfacing Linkam PE94 with labview
Hi everyone,
I am trying to use labview 2013 as an interface for a Linkam PE94 temperature controller via a RS232 cable.
I can read from the instrument using the "T" command and a simple read/write program. However, I cannot get it to accept commands that control settings such as the heating rate command ("R1") or  temperature limit command ("L1").
Has anyone had a similar problem or perhaps could suggest where I might be going wrong? Any help is appreciated!
Aimee
PS Then manual for the temperature controller can be found here
 http://forums.ni.com/ni/attachments/ni/250/69925/1/serial%20commands%20for%20t92-t93-t94%20100%20ram...
(3,566 Views)
HI aimee 123,
Check thist forum, it might help.
http://forums.ni.com/t5/Multifunction-DAQ/LabVIEW-8-5-and-Linkam-Stage/td-p/1928555
Regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,562 Views)
Thanks Sabri,
I have seen this forum and tried to use the .vi attached within it. My instrument only responds to the T command. If I run the vi.s that tell the instrument to start ("S") or to set the temperature limit nothing happens - I don't get an error message - just no reaction from my instrument.
I can set the parameters from the front panel and use labview to record the temperature remotely but ideally I would like to controll everything from labview.
Thanks for your suggestion,
Aimee
(3,548 Views)
