Trouble triggering the event structure with the "time has elapsed" boolean on the elapsed time function
I have been unable to use the elapsed time function's output "time has elapsed" to trigger a subsequent event in the event structure.  Is this possible?  I have no trouble using the event structure when the triggering event is a boolean control.  I have attached my VI.  Any suggestions would be much appreciated.
(2,347 Views)
Writing to a control does not trigger an event. You can create a property node and write to the Value Signaling property. But the event structure has a timeout case. You could put your code in there and write the number of milliseconds to the blue hourglass in the upper left hand corner of the event structure.
LabVIEW 2012
(2,346 Views)
