Trouble using NI_MAPro.lvlib VIs inside a "Plug-in"
      I'm trying to use NI_MAPro.lvlib."Trigger Detection for 1 Channel" inside a VI that's called by name (the "Plug-In"). If I run my application in the Development environment, it works, but as an EXE, the plug-in opens-broken. If I remove "Trigger Detection" (and all the other NA_MAPro VIs) from the plug-in, it "runs" unbroken. I've replaced the "Trigger Detection" SubVI with a CLF calling the same dll (lvanlys.dll) - and the "plug-in" runs - in other words, it doesn't seem to be a DLL problem. I've even configured "Trigger Detection" to open it's FP on load, and it opens UnBroken, though the caller (the plug-in) is broken.Smiley Mad
I suspect it's a lvlib issue, but am inexperienced with these things and out of ideas!
SINCE posting this to the worng forum, I saved Trigger Detection and two others as new-VIs, outside a lvlib, and the Plug-in is happy/working, though...
It would still be good to know how to solve this without having to re-create lvlib VIs,
Any help is appreciated.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,805 Views)
Hi tbd,
Can you post a simple VI which shows this problem? And which version of LabVIEW do you use?
Michael
(3,783 Views)
Hi Michael,
      Thank you for the reply.  I'm using LV 8.5.1, but, at the moment, can't reproduce the problem when I develop a simple example project which builds an EXE that calls a plug-in.
So it seems to be a lvlib-related problem on my development station.  I'll recompile the example there (later) and post the project if the problem recurs.
Thanks/Cheers!
(3,770 Views)
Hi Tbd,
I am facing similar problem. Did you find any solutin to it.
Vikas
(3,409 Views)
Vikas,
Try going into your build spec and unchecking the "Remove unused members of project libraries" in the "Additional Exclusions" section.  If a library is used in multiple locations, this feature can sometimes create a situation where LV tries to load two libraries of the same name but with different contents.  This is generally the source of the error.
Hope it helps!
JasonP - CLD
(3,404 Views)
